I recently restored an Atlas 3995 lathe. Spindle bearings were absolutely unworn and not replaced. TIR of spindle ID is .0011. The Cushman 3 jaw chuck OD indicates .0043. I cannot get a decent surface finish on virtually any material with any cutter type. Speeds and feeds all within spec. The chattering when parting off is just about unbearable. The cuts appear as if the cutters are literally moving in and out against the workpiece. I could get a better finish with a drill press and a file. I have close to one hundred lbs. of steel shot bags sitting on the lower cabinet shelf to add mass. I do have the lathe on adjustable machinery feet vs. sitting directly on floor. The bed is very level (twist). Even close to the chuck the finish is typically awful. I have used HHS, carbide inserts, and standard carbide on free machining steel, mild steel, brass with more or less the same result. I have checked and rechecked the gibs for all slides, the preloading on the spindle bearings. It has an Aloris tool post.
I am beginning to believe the lathe may never make a decent surface on a consistent basis. Looking for help on what to attempt next.
Thanks.
Thanks.
