- Aug 23, 2014
- 222
On Saturday, finally got around to putting the Atlas back on it's screw jacks after rearranging the workshop a while back.
On Sunday, power was out for a while, musta got bored, i dunno....
Now I'll have to clean up reassemble. While its apart, I'll make some changes, do a bit of fixxy and get some better photo's of some previous repairs/mods.
Bit of history as I know it, purchased about 2011 from an elderly gent in Mandurah, W.A.
Had suffered a major crash somewhere along the line, the change gear banjo has been repaired, the fwd/rev gearbox had quite a lot of bentism and the toolpost is now only a plinth with a 4way turret.
So far, the motor has been replaced and a fwd/rev switch installed, new spindle made, fwd/rev gearbox straightened and some improvements applied, compound adapted from another lathe, along with quite a few other repairs and modifications.
I'll try to remember them all.
Already found something a little odd, Bolts/Holes for attaching feet to bed appeared to be 1/4"U.N. to me(Course for headstock end and fine for tailstock end).
Closer inspection of the bolts says otherwise, with the course bolts measuring 6.75mm O.D. and the fine bolts at 6.7mm O.D.(1/4" is 6.35mm). The T.P.I. for the course bolts seems to match NC 20 but the T.P.I. for the fine bolts is nowhere near NF 28, maybe 26 T.P.I. not sure yet.
Are these a special made by Atlas?
