R
Robert LaLonde
Forum Guest
Register Today
Yep, the fed is ok with gatlin guns. Ca, Ma, Il and one or two others would probably treat you to life without parole for being in the same county with one. The same states that would have an issue with a trigger cam crank. Az, Nv, and Tx would probably praise you for being prepared. Also, some cities such as NYC have aggressive anti gun ordinances in addition to the state statutes.
Unless you have a source for a bunch of barrels the best way to go is probably to get liners and gun drill your own barrels to glue them into. Of course old rifle barrels will work if you have a pile of them around. Numrich often has off cut pieces of barrel liner at a discounted price that might suit your needs. Brownells stocks Redman liners, and the guy who makes Redman liners is open to bulk purchases in .22. I talked with him once about using his liners for high power PCP rifles.
