- Feb 1, 2018
- 1,862
I didn't read all the posts. I did want to say I stopped hammering or pressing on bearings several years ago. I made a cone bearing heater. I used a 4" diameter x 8" shaft of aluminum and turned a taper on it from my lathe compound - over approx 6" I went from 3" to 1/4" taper. Then flipped it around and drilled / bored a 1/2" clearance hole in about 6" long. Ordered a 110 v heat sink from Grainger and slid it in the hole, locking it in there with a plate. I set the bearing on it, plug it in and use a infrared heat gun to test the temp and when the temp raises the to 140 F which takes about 5 minutes. Then using a channel lock drop the bearing on the shaft. The heater expands the inner race a few thousands and it slips on , slicker then shise. You can but them for under $1000.00, but I made mine. It works super. I can go and take a few pictures if needed. It's out in my shop. I've never tried this, but a customer of mine used to lay the bearing on a cookie sheet and heated the bearing up in their cafeteria gas stove oven to 140 degs. They had a rolling work bench with a vise they rolled into the cafeteria....lol....That worked too...
