I missed seeing where it was said that the ER32s were of different outside sizes or angles than standard ER32 collets. It is clear that the Vevor and like machines use the collets in the reverse orientation, but so far I've not seen or read anything that says a standard ER collet doesn't fit the Vevor style collet chuck. I tried to point out above that the Vevor style collets in the smaller sizes don't have jaws that bear the full length of the collets, which would preclude using those collets in a standard ER collet chuck. But I see no reason the opposite is true, that standard ER collets cannot be used in the Vevor style collet chucks.
Below are drawings showing dimensions of ER20 and ER32 collets. I checked the drawing against the ER20s in my Vevor set and they match, at least close enough. No drawing or specs I've seen yet shows the inside geometry (but no images show them from the back either), so my assumption is that they are the nominal ID the full length.
If you have ordered both, you should be able to try them out and let us know.
ER20
ER32
It looks like the Vevor orders should arrive Monday.
I am excited to compare to my old Drill doctor, and confident this machine should do a much more precise job of it.
It shure would be nice to be able to sharpen some bits larger than 1/2" I thought about ordering the large Vevor unit, but at virtually double the price -just could not justify buying it.
Wonder if there is a work around with the collets or a way to make a new holder ...??
