- Sep 24, 2010
- 3,096
This is a great thread!!! The theoretical discussion is even interesting as well. In welding however the arc wander is just a source of irritation that must be minimized to prevent slag inclussions and imperfect weld zone. A wandering arc causes localized heat affected zones that cause Martensite formation and Helium inclusion in the base metal. These two formations negatively afeect the quality and strength of the weld at a molecular level. If you are welding and notice that the arc is wandering (and you will notice), you need to either move your ground or move your magnetic squares further away from the weld. Once you have experienced the arc wandering you will begin to notice about how close you can get before it begins happening again. Best practices dictate that once jigged and properly tacked mechanical means of retaining the joints designed angularity is better than a magnetic means every time. That is why I frequently weld my jigging fixture to the surface of the welding table and only remove the jig after the completed weldment has been allowed to cool and been removed. It makes setting a repeatable and uniform spacing in a quick and easy no hassle way. This will increase through put and fatten the wallet. The result that we are all looking for ultimately. Great discussion!!!
Bob
Bob
