- Nov 16, 2012
- 5,596
In theory, agreed. In reality, calculate the magnitudes. Yes, a DC current in a wire produces a magnetic field -a very weak one which is why you need to wrap a wire thousands of times around a ferrous core before you get an effective electro magnet (right-hand rule: i.e: the mag fields are additive). The amount of magnetic field in an open-gap circuit? Something tells me if you calculated the relative strength of the electric vs magnetic fields under those circumstances, you'd see a negative double-digit number in the exponent. The context here was addressing another poster's comment that self induced mag fields were causing the plasma to wiggle. In this case, the electric field is driving the plasma insanely in one direction and the influence of the mag field is about as close to zero as you can get.
I'm going to disagree with you on this part (and this part alone). A current produces a magnetic field, period. There's nothing in Maxwell about current in a wire being different from current in an arc (plasma). It's right there in the equation that has curl B (B is the magnetic field), and J (J is the current density). http://en.wikipedia.org/wiki/Maxwell's_equations
