This take-down pin set screw setup deal seems to be pretty good. The design is using 1/2" long 1/4-28 version of these:
http://www.mcmaster.com/#set-screws/=uwt09x
and a 1/4" long one of these as a locker:
http://www.mcmaster.com/#set-screws/=uwt9ai
It is drilled/threaded from the bottom centered on the take-down pin. The drilling operation goes through the end of the AR handle tab up. I have built four different AR's and with upper assemblies from different vendors. The last one was a bit sloppy and was considering getting oversize pins from Brownells. This would probably help take up the slop.
-Joe
-Joe
Those lowers from Broken Arms look interesting and I'll be looking for your assessment once it's in your hands. Will you have to modify your clamps/holders for the more angular shape of the lower or are they still within "spec"? Their use of a set screw to take up the slop between the upper and lower is "interesting" to say the least but I'm not sure I am getting my head around just how it functions. Does it just put pressure on the upper's "take-down" tab?
