- Dec 8, 2013
- 2,648
If this were my project, then, after cutting the acme threads, and using this pic as an example, I'd probably setup my mini toolpost grinder like this, and make 'thread cutting' polishing passes inside the nut, concentrating on the thrust side of the threads. Could use a V-edged wheel, or trim/dress a cylindrical wheel, and/or tilt the grinder to match the pitch angle of the acme thread. Or, look into the softer, more-compliant G-flex wheels mentioned by holescreek above.
As far as the colors and grit sizes go, I'm not quite sure how to answer that. Yes, these wheels have a grit of particular sizes, but the results don't really match what you'd get with sandpapers and such. Almost like a world of its own. Takes a bit of playtime to get the feel of the various grades, and how they work on different materials. This pic shows my results with the Craytex 'medium' grit on an ER32 collet. It's not a mirror finish, intentionally, because I wanted it that way.
I was thinking of putting one of the Craftex sticks in the boring bar and going over the threads with it, but I may try your idea. Looks like the medium would work for me. I don't need a mirror finish, but realistically I know that my threads are going to have enough burrs and roughness to impact efficiency.
