I have a used enco 13×40 lathe. As is common with asian lathes, the head stock is adjustable. When I first moved the lathe into my shop, I leveled it with a make shift plumb bob level and it cut pretty good for a newbie. Then one day, I crashed the carriage into the headstock and it began cutting tapers.
I did a lot of reading about leveling a lathe and found almost all discussions related to leveling lathes with fixed head stocks. My concern was that I believed I shifted the head stock alignment when it crashed since its unlikely that the leveling was impacted.
I read a post that suggested to face a large diameter disc and check the face with a test indicator to check head stock alignment. As the test indicator moves across the face on the back side of center, it will show misalignment. I aligned the headstock with this method with the largest diameter I had, about 4 inch, and the lathe cut pretty good again.
Now my projects and skill require more and more accuracy. I want to properly level the lathe and check alignment of the headstock more accurately. I plan on facing a much larger diameter disc to check head stock alignment, but was wondering if I should invest in a machinist level to start the process on the right foot. The Starrett 98-12 is accurate to .005 in 12 inches. Is this the way to go or is a different level required? Is a 98-8 or 6 acceptable as the are not as pricey? Should I level first, adjust headstock next, and then cut test bar for taper indication?
Thanks for any input here.
