I am a little late with this question since you have used this technique on several flywheels, but how does the taper lock work? Is there a matching taper in the flywheel hub? How do you hit the dimension correctly?
I set the compound some where around 5 degrees and it doesn't have be exact. Now don't change the angle until you have cut all the tapers for the flywheels and the lock flange. They come out perfect every time. Thanks Robert
