Thanks!Verrrrry nice job.
Very nice! I actually thought about attaching mine to the threaded holes in the front of the vise as you did. I like the slotted cutouts to allow for easy removal or adjustment. Clever.Nice looking truck and chip shield too tjb
I swear for a second from your photos I thought they were from my shop... i had to look closer on my phone to be sure. You have almost the same vise and plywood walls and wood table covers. That helps cleanup for sure plus you dont lose drills and stuff rolling into the t slots.
I took a more minimalist approach to shielding with a slip on pc of some mystery plastic on hand at the time.
Also one of the reasons for putting the mill in a corner was to semi- contain chips to a more confined area.
For side chips I ghetto rigged (o crap can we even say that anymore??) a small moveable one using pressboard and a vblock vise jaw for weight.
Not perfect but keeps the big stuff from getting all over the wall items and collapses for quick easy cleaning and storage or for job setups!! Pics make it look way too clean but in reality Ive used the heck out of it. And I dont ever use coolants just air or small drips of oil etc
Thanks, Aaron.These are the magnets and little boxes I was planning on using. Thought I'd probably just silicone the box to the poly carb sheet. The boxes came from Tap Plastics (I love that place) which is also where I got the poly carb sheets. The magnets are cheapies from Harbor Freight but pretty strong.
I was looking at the whole thing as semi-consumable so didn't want to get too involved with it. I'm only into it for about $20 so figured if it lasts a year that isn't bad.
Really nice ! Excellent photos, thank you.I made this chip shield out of clear plexiglass and some scrap aluminum. I did a lot of head-scratching before beginning the build. I tried to anticipate every conceivable application with regard to size of milling projects and safety. Once I zeroed in on these criteria, I came up with a design. The end result has a center panel and two 'wings'. The center panel also has upper and lower adjustable panels to allow for over-sized milling projects. The wings are connected to the center panels with hinges I made from 1/2" aluminum, and the rods were from a piece of leftover 1/4" brass rod (would've liked to keep that one, but I didn't have any scrap 1/4" rod available). The movable parts are secured with stationary threaded studs and wingnuts - no need to hunt for a wrench. The three-panel design allows for adjustments in essentially every dimension to accommodate small to large milling projects.
The unit is very sturdy sitting on the vise, so I'm still trying to decide if I want to add magnets to the base. I'm trying to avoid that if possible - I anticipate I'll be using this regularly for steel projects.
Regards,
Terry
View attachment 330958 View attachment 330953View attachment 330954 View attachment 330955View attachment 330956 View attachment 330957
Love these ideas. I have some 'junk' 1-2-3 blocks that I'm going to press into service using your ideas.Nice looking truck and chip shield too tjb
Good idea, David.Love these ideas. I have some 'junk' 1-2-3 blocks that I'm going to press into service using your ideas.
