Thanks!You're right, nope I would have never thought. I could not accept any credit whatsoever for your ideas, that's all you, mine was just a simple shield. Yours looks like it covers basically everything one could think of. Spectacular work!
That's an interesting idea. I would very much like to see photos of the plastic boxes you've described and what you're developing. The 'tripod-style' design on mine makes for a very sturdy base, but I would still like to investigate other options.Very nice, I really like the sliding section.
I've been looking at making some shields for my mill, I've gotten as far as buying some poly carbonate panels. I was planning to use magnets, but to deal with the issue of steel shavings I got these small plastic boxes for the magnets to go into. I'm hoping that will work like those magnetic pick up tools where you lift the magnet and the shavings fall off, but worst case I'll just take the magnet out and clean off the box. Then put the magnet back inside. If the magnet collects shavings no big deal because it will be inside a plastic box where it can't hurt anything.
Thanks, David.Looks great. Well thought out design.
1954 Chevy 3100. Complete frame-off modification:tjb, Please tell us about that truck in your avatar.
You don't need to steal it. I posted it here for the very reason that someone might benefit from it. I consider it a woefully inadequate expression of universal gratitude for the great advice I've received from so many of our experts and more experienced hobbyists. Just about everything in my shop is based on tips and recommendations I received here. THRILLED that some others may benefit from the design.Nice work! I might have to "steal" ideas from this. The flycutter makes one heck of a mess.
Verrrrry nice job.I made this chip shield out of clear plexiglass and some scrap aluminum. I did a lot of head-scratching before beginning the build. I tried to anticipate every conceivable application with regard to size of milling projects and safety. Once I zeroed in on these criteria, I came up with a design. The end result has a center panel and two 'wings'. The center panel also has upper and lower adjustable panels to allow for over-sized milling projects. The wings are connected to the center panels with hinges I made from 1/2" aluminum, and the rods were from a piece of leftover 1/4" brass rod (would've liked to keep that one, but I didn't have any scrap 1/4" rod available). The movable parts are secured with stationary threaded studs and wingnuts - no need to hunt for a wrench. The three-panel design allows for adjustments in essentially every dimension to accommodate small to large milling projects.
The unit is very sturdy sitting on the vise, so I'm still trying to decide if I want to add magnets to the base. I'm trying to avoid that if possible - I anticipate I'll be using this regularly for steel projects.
Regards,
Terry
View attachment 330958 View attachment 330953View attachment 330954 View attachment 330955View attachment 330956 View attachment 330957
