- Dec 25, 2011
- 10,552
Steve,
The bushings were made for solid round shank cutters. The flats were ground until there was a gap in the middle. When you put a solid shank in the bushing, the OD of the shank actually sticks out through the gap enough that the nose of the set screw tightens against the shank and doesn't push on the flat surface of the bushing. So it doesn't deform it. If you put a Weldon style cutter shank in the bushing, the only thing that the set screw touches is the flat in the bushing. So it only holds the cutter by deforming the flat in the bushing into the gap in the cutter shank. After that happens, you can't get the bushing off of the cutter.
