- Aug 22, 2017
- 83
Hello 34_40,
Thank you for your suggestion about looking at the other thread for the kick out. I've been trying to read that whole thread for a while now and never got to the part you suggested. The one that came with Steve's Atlas mill definitely looks like it would be easy to make. One question though (and I didn't see it in the thread) what is the O.D. of the round area of the kick out?
Also, a little update on my progress with my Atlas horizontal mill. If you have been following this thread then you know that I have already done a full rebuild and I am in the process of putting it back together. Last night I put the motor on, I would have done it sooner but I needed to figure out some of the wiring. For some reason the person who owned it at one point put a forward and reverse switch on it as well as the on off switch. And I wanted to put the on off switch in the original place in the column. I still need to figure out where I am going to put the forward and reverse switch?
Anyway, I put the motor on and then put the belt on. Adjusted both belts to the correct tension and flipped the on off switch ON to see if everything goes smoothly. Low and behold the mill runs like a champ with no noise coming from the gears!!! So that was good to hear and know that just maybe I did something right for a change.
Next was to check out the Change-O-Matic gears and see how the table feed works. This is where I ran into some sort of problem. When I put the Change-O-Matic on to see if the table would move. I noticed that the spindle was turning and so was the 3 step pulley in the head. But for some reason the gear that engages the Change-O-Matic lever was not turning? So I put it into the back gear and turned it on, then the Change-O-Matic gears started to turn and the table started to move.
So I guess what I am asking is, I'm I missed something with the 3 step pulley? When the mill is not in the back gear, the 3 step pulley just turns and does not engage with the Change-O-Matic gears? Any help on this would be appreciated.
And on a parting note, while I was messing around with the mill. I went to take a look at some of the stuff I got when I bought the mill. Apparently I have the 1" arbor and a bunch of collars to go with it. As well as the arbors for angular cutters and the cutters that go with it. And something I found interesting was that I have these little things called End Mill Bushings, part number 563E. Required to adapt all 576 end mills to No. M1-577 shank-cutter adapter (which I have). Can anyone help me with what these are and how exactly do I use them? I assume that they are for the M1-577 shank-cutter adapter so you can put smaller end mills in the M1-577 adapter. I also have what looks like a piece that goes with the M1-570 Shell End Mill Driver. So I gotta look around for the other piece that gets threaded on to the spindle.
I'll see if I can post a video of the mill running so you can see what I have going on with it.
Orangecrush
Orangecrush
