- Jan 22, 2011
- 8,016
Cutting it off will do nothing to gain threads. If the drawbar is indeed bottoming out, then a spacer is the easy way out. Seen them on drawbars many times. It's possible your drawbar is just too long. How much excess thread do you have that extends past the threaded portion of your collets? If 1/4" or so, cut off the drawbar and call it good. If it does extend past the threads in your collets, you are shortchanging yourself on how much end mill shank you can swallow in the collet anyway.
