- Jan 28, 2022
- 1,503
I have my unit serviced at the beginning of the season. In the five boroughs of New York its common for appliances to suffer from Brown Outs ( voltage lowered ) to which the supplier will not admit being the problem. Compressors, pumps, motors and start relays burnt/damaged.Shut the power off to the a/c unit. Inside the control box is a capacitor and a sealed timer, check these units. If you are unsure how to test them then ask here. CAUTION a Capacitor can hold a charge for an unknown amount of time again with the power off . Short the capacitor legs together with a screwdriver. Mark for the wires for identification and remove the wires. Test the capacitor. The second small box looks like a sealed relay . If the motor starts up it probably is not the capacitor if it is a lack of cooling it is more than likely the relay.
I bought the capacitor at HF 15.00 and the Relay 22.00 through an Appliance repair supply.
These components are hit hard by the sudden loss of power or sudden return of power.
Safety first. VERIFY power is disconnected and be wary of a low voltage signal present from a low voltage control transformer.
Or just call a repairman...stay cool
