If your okay with buying the couplers than why not buy a 1/4 set and bore one side out 1/2?
One crude coupler would be a flange on each shaft with two holes spaced equally apart. Then use some reinforced rubber with your hole spacing but make the holes in a cross pattern. Two holes connect motor side two holes connect device. The coupler will allow slight misalignments and depending on rubber used will handle lots of torque.
