Okay so good news and bad news.
Good news is got to look at it and he's holding for me while I think about it. It seems to rotate nice and smooth. It comes with a rotating table and an extra X Y vice to use with the milling machine.
Bad news is the motor for the milling machine doesn't work. It hums but doesn't spin and a few cooling fins are snapped off. I'm operating under the assumption the motor will need to be replaced. Also, the fibre gear on the left has sustained a bit of damage on the right side of it. I'll try to add a picture I took. I would love to hear if it's enough to expect a failure in the future or just clean it up? It also doesn't come with the centre for the tail side. I believe it's called the live centre?
Other than that I think it looks decent. The seller knows as much (or as little) as I do about machining haha. Which is none. He hasn't used it himself. There isn't any tooling with it but he said he'd take what would equal about $1450 USD.
Additional advice would be very appreciated!
That lathe will clean up nice, I think.
The fiber gear looks like the owner shifted the gears while the lathe was still running. The damage looks minimal and I suspect that if you are careful to let the lathe stop before shifting, it should hold up fine.
The mill motor can be replaced; watch ebay and one will turn up.
You should understand that accessorizing a lathe may cost as much or more than the machine itself costs. This is true for any lathe you buy. What is lacking is the steady and follow rests; these are important. Also important is the complete change gear set; no lathe is complete without it and eventually, you should try to obtain it. A live center is not overly expensive. You will eventually need a drill chuck for the tailstock and a quick change tool post. Otherwise, the lathe looks good.
$1400.00 for an Emco lathe is a decent price, especially one with a milling attachment on it. Do you own a dial test indicator? If so, remove the chuck and indicate the taper in the spindle. It should run with very little, if any, run out. Emco lathes are very precise machines and even the V10-P had a hardened and ground spindle that should be very accurate. If it run out significantly, then either the bearing preload needs to be adjusted (easily done) or the bearings need to be changed.
Also check to see if there is excessive wear in the ways. Visually look for damage; if none is found then tighten the saddle locking bolt on the right side of the saddle. It will be on top and if you look underneath there will be a plate. Move the saddle to the headstock end and snug that bolt until the carriage moves with just a little effort at the saddle handwheel. Then move the saddle toward the tailstock. If it moves with about the same effort then the bed is likely in good shape, but if it gets really tight as you move down the the ways are significantly worn. You can measure this but this simple check is enough.
If you find anything off, and assuming you want the machine, then use it to leverage the price down.
