- Jan 16, 2017
- 216
I measured between a finished vice jaw and got the measurement I needed...
+1 on the tolerance for the dovetails. That is a precision dimension, not to be taken lightly unless you have a good use for scrap metal tool holders...
Hey, smart move. Let the others make their mistakes and benefit from them, so when it's your turn, you will get it right the first time.I chickened out and just squared my other piece and milled the slot out. I am going to wait until others start their dovetails to see if I can learn from them as well. I already have everything programmed on the Prototrak so it won't take me that long to mill the other stuff out. Thanks for all the help!
When I went in this morning I wanted to tackle it, but my better judgment told me to wait. I did however find 2 pins that were exactly .250. I measured between a finished vice jaw and got the measurement I needed for my own so I'm 100% sure my method will work.
Got to make one! The P.O.S. one I bought from Little Machine Shop has over a 1//32" runout in it.Don't want to keep you guys in suspense...so in the mean time here's a spring-loaded tap center project I just completed....
Oh, the dovetail cutter you use will have a radius on the corner. It may only be R0.001" but its there. Probably turns into a R0.005" once the dovetail cutter is broken in, or much worse. I've knocked off the sharp corners of a dovetail mills to something like R0.030", more than once, too!
Brino,Hi Ken,
I have a project that requires some dovetails (also lathe tool holders).
The dovetails cutters I found have extremely sharp points(see below).
R0.001"? .......yeah maybe, it's tiny.
The project can stand a fairly large radius, as the existing tool holders have perhaps > 30 thou.(estimated with calipers)
I have an assortment of bench grinders, but NOT any kind of tool and cutter grinder.
Would you advise trying to grind a radius on the sharp dovetail points?
If so, then how?
The points look very fragile, and I'd rather lop them off in a controlled manner then have them snap off uncontrolled.
Thanks!
-brino
View attachment 230081 View attachment 230082
