- Feb 5, 2015
- 662
I am not sure what I am shocked at: the fact that the caliper withstood all that weight without damage or that you managed to balance that weight precariously on the step end .
And I would like to restate my position on this, Calipers are not sensitive to measuring pressure, but the parts you measure will be affectedif you do not repeat the pressure exerted.
Ha-ha, you're right to be shocked at that balancing act. It probably required a full minute to stabilize the larger weight on the end of the calipers and since I live in earthquake country, I hastened to take the photo before quickly removing the weight.
Regarding damage, recall that we are discussing a $15 set of calipers (that are over ten years old, BTW). I had little to lose but these devices are so simply constructed and sturdy that I would have confidently used a heavier weight if I could have balanced it, LOL.
OK, your position is now clear that you are NOT of the school that feels caliper pressure is important Thanks for the clarification.
Insofar as parts being measured being affected by pressure, well sure for very soft materials, that's why I mentioned using a light touch on plastics. I don't think repeatability of measurement pressure is an issue for the typical HSM (unless measuring urethane foam or something similar - in which case precise machining is all but impossible anyway).
In an industrial environment (like yours, I infer), you are best qualified to determine the proper measurement technique for characterizing the dimensions of the material you are processing.
For harder materials, the experiment indicates that the pressure exerted and repeatability is uncritical. For softer materials, I simply repeat the initial statement:
....When it comes to plastics, obviously a soft touch is best
I find that variability in readings with applied pressure is greatly affected by the sliding fit of the movable jaw. If the adjustments are loose, it is almost impossible to get consistent measurements. My B & S dial calipers are similar in response to Randy's. Measurements are most reliable when made close to the beam.
Deflection of the jaws due to fit will of course multiply the error depending on the location of the part in the caliper jaws. In the experiment that I conducted, the near nine-pound load would have multiplied the error at the end of the jaws resulting in about .002 rather than .001.
In my opinion, that's a fairly trivial difference given the magnitude of the load. And the fact that this incredibly cheap set of calipers performs much like your B & S pair suggests a few things
- this particular pair of imported calipers are obviously of good quality
- as a mass-produced product one might extrapolate that most calipers like this one are of good quality
- B & S calipers are known to be of high quality
- based on performance comparison between low end and high end (my cheap calipers and your nice B & S pair) we might make a presumption that the design/construction of this class of tools in general is excellent, capable of most tasks (other than high precision) required by the HSM
Makes me want to order a few more sets from HF
