B
Bill Gruby
Forum Guest
Register Today
By the time everything is on the table we easily gone over 50 lbs. Is the lift out really going to be that much of a problem? Just thinking out loud. LOL
"Bill"
"Bill"
You could confine the rack with a guideway and have the table engage it via pins. The pins could attached to either the table or the rack.I don't know about an actual requirement..........that's on the designers, lol..............but yes, it would sacrifice that. Personally I have not had many pressing needs to remove a SG table, and the work required that prompted the need far outweighed the inconvenience of stripping cables or whatever drive.
But, if that were a design requirement in this case, then some consideration might be made to make the driven section integral with the table and the drive easily removable in the case of table removal.
Another loony idea: a chain drive. A sprocket at each end of the base, one free-wheeling, the other driven by the crank. The chain would be stretched around the sprockets with a plate in the middle with a pin to engage the table (or a hole for a pin on the bottom of the table). The plate would slide on the base or ride just clear of it. The chain and sprockets are cheap off-the-shelf parts (I'd salvage them from junk). No lift and no precision work. Could use toothed belt instead of chain.Many of these ideas are good , some great,but we have to consider one other thing. We can't get to complicated on this because it not only increases cost considably, but over complicated systems pose a challenge to build. We need the simplest solution that will work the best, WITHOUT sacrificing quality. I am not convinced the lift will be a huge problem. Many surface grinders have a table that just sits on the ways, but they are also MUCH heavier than ours. All that said, I'm going to watch a bit and see what else we come up with. There is a lot of great thinking going on here.
Tony ,Mark, nearly all design work is a compromise. At this point, early in the process, the idea is to explore. Once the resources are exhausted, the choice can be made to include or exclude what fits the actual requirements, but not necessarily fits the ideal(s).
