Wow! That's a very thoughtful suggestion. I had to read it several times to visualize it, but I think I've got it. (Do you have such a setup? Any pix?) I see what you mean about milling the miter being the 'tricky part'. That step would definitely require a lot of precision.
Thanks for the suggestion. Making the fixture would be a challenging and fulfilling exercise in itself.
Regards.
We do have a drill guide or 2 that we have made for various projects.
One was steel and other aluminum.
We needed a square to surface hole at a repeatable place reference to a corner so we took flat aluminum and milled it out so it could rest on the surface with a recessed area causing 2 faces for stops
We then dug in the bolts and since we had many 5/8 grade 2 leftover from shop we drilled and tapped 5/8 on the plate where the hole needed to be and in the lathe drilled the 1/4 hole in the bolt and then screwed it into the plate and held with jamb nut.
Easy to make and length of bolt insures hole is drilled straight with portable drill so clamping your project can be done flat
If you offset the hole then flipping fixture allows it to be used on 2 sides
Have one side be centered and other side as the offset one
It then can be used first to drill holes then before moving tap them as it holds tap straight too.
Then use Allen set screws to temporary hold in place then flip and do last &olé on other side needing 2.
Insert final screws then do next corner.
