- May 3, 2017
- 2,026
Thanks, Robert.Would you consider welding the joints on the inside?
Robert
Yes, life would be much simpler with a weld, but my application requires a clean, crisp inside corner.
Thanks anyway.
Regards,
Terry
Robert
I thought about using a countersinking screw, but I need the outside surface to be flat, flat, flat. Maybe I'm underestimating myself, but I was concerned that over- or under-cutting the countersink might result in a very ugly mismatch. Do you run into that issue?I always use 18-8 Stainless Steel Hex Drive Flat Head Screws for that type parts.
https://www.mcmaster.com/#standard-flat-head-screws/=19o7tzi
Because flat head screws have a short cylindrical section, there would be a small groove on the circumference of the screw head if the screw was set flush. There would be two work-around's. Use a countersink the same diameter as the screw head or very slightly larger or set the screw proud and machine them flush after the box was assembled. Another technique would be to use a low profile socket head cap screw and set it below the surface and follow with a plug. With finishing, the plug would virtually disappear into the wall of the box.I thought about using a countersinking screw, but I need the outside surface to be flat, flat, flat. Maybe I'm underestimating myself, but I was concerned that over- or under-cutting the countersink might result in a very ugly mismatch. Do you run into that issue?
Regards,
Terry
