- Feb 1, 2015
- 9,995
I had air inclusions in my slug but I attributed that to my method of heating. Even though I made an "oven" out of fire brick, the bottom was cooling below the melt point. I expect that the temperature has to be a fair degree hotter than the melt point to get good flow or to allow air inclusions to work their way to the surface. As i recall, the temperature for injection molding was fairly close to the melt point so minimize shrinkage and warping. We also used a fairly high pressure to pack the mold.Did you end up with a solid chunk without porosity in your slug RJ ? I'm curious . The wedges ended up being porous due the extruders just dumping into the mold and not under any pressure . It would be cool to make up a few cheap arse molds and be able to dump the heated plastic right into them , or put the mold onto a hotplate and melt it . Hm ..................you have me thinking .
