- Feb 1, 2015
- 9,995
No need for a carousel as the stand is quite compact. In fact, it is easily and reliably moved by just grasping the cluster of larger drills. Placing the larger drills in the center rather than all the drills on a single circle makes it a very stable stand as well as compact.Very interesting project, are you completely done with it now? I mean is there something else you're planning to add to it, like labels for the smaller drill sizes? or turning it to a carousel? just thinking out loud.
As to labeling, I wondered what I could do in that regard. Certainly, the CNC was/is capable of engraving the sizes. The inner circle is fairly tight and it would be hard to read any size. As for now, I will probably just verify the size with a caliper. If that becomes too annoying, O will take appropriate action.
