- May 7, 2023
- 2,242
Talking about the feed motor for the leadscrew.
No room at the front under/below the (custom) control panel and I will not mount the motor sticking out the side of the change-gear cover as that would mean the lathe not fitting in the space I have for it.
I literally have the width of the lathe (outer end face of change-gear cover to tailstock end of bed) plus 4" which is more like 3-1/4" when I have it moved forwards and bolted down. Heck, the space is that tight, I can not even get the tailstock off when the lathe is bolted down.
I’m thinking of possibly mounting mine under the tailstock inside the bed and having a shaft come out the rh side with a set of clogged pullies.
Pretty much just to keep the side cover form factor the same.
