- Jan 1, 2018
- 1,215
Make sure your VFD is rated at 3Hp and the output amps are sufficient for that size motor, that is a big increase in Hp for that size lathe. You may also use a smaller motor pulley and over speed the motor to something like 100Hz, will give you a wider speed range.
The motor on my South Bend 13 runs smoothest at 80-100hz. The whole lathe is quieter and smoother. I always figured 60hz is an artificial limit for motors because it is what the power company gives us. Even though the motors are designed to run at 60hz I don't believe that means it is the frequency they might run best at.
