- Apr 30, 2015
- 11,885
Nice anvil you got there, Yota
I run up to Pa 20 minutes away and get the un-ethanol also . It's helped over the years . I think I need to do some cleaning on these saws as they all ran last year . I had the same issues with the weed whackers earlier on .it works because its ethanol free. I just get non eth at the pump.
I put that garbage in my vehicle the first year I moved to Utah, They call it E-85 here. What most people don't understand about it is, You get 20 to 25% less fuel economy, So even though it's 10 cents a gallon cheaper because it's subsidized, You are burning much more fuel and it costs you much more. Plus eventually it will deteriorate any rubber in the fuel system unless your vehicle is branded "Flex-Fuel".it works because its ethanol free. I just get non eth at the pump. the only thing I run ethanol gas in is my truck.
so far florida has only allowed use of 10% ethanol. still won't put it in anything but my truck.I put that garbage in my vehicle the first year I moved to Utah, They call it E-85 here. What most people don't understand about it is, You get 20 to 25% less fuel economy, So even though it's 10 cents a gallon cheaper because it's subsidized, You are burning much more fuel and it costs you much more. Plus eventually it will deteriorate any rubber in the fuel system unless your vehicle is branded "Flex-Fuel".
