3 axis DRO installation on a 9x42" Bridgeport Mill
Any updates on your installations,what kind of DRO did you go with?If possible post some pics of your process,love to follow along----kroll
What you may want to do is put a small stand off below the scale for the X axis so you can't run the table into the column when cranking it in. The pic I posted shows my scale with just a 5/16 cap screw used as my stand off. If the table is cranked in too much the cap screw will hit the column instead of the scale.
My lathe didn't come with a DRO so I bought a three-axis unit that I haven't installed yet. The mill came with a two-axis DRO on it. I've purchased a lathe tail-stock battery operated DRO and am planning to put the three-axis on the mill and transplant the two axis to the lathe. I haven't checked yet to see if the slides are interchangeable. Sounds like from the thread that the z-axis usually goes on the table. I guess one could also put a tailstock type DRO on the quill.
