Know what you mean. Just figured someone who has done several of these has probably researched it pretty well. I did take a quick look on e-pay and here is the higher end DRO-PRO version. The descriptions can take a little evaluation if your not familiar with all the terminology. Thinking someone who is more familiar with them could clear up some things for those of with less experience. Mike
- 5 um (0.0002") resolution scales (display supports 0.1-10 um scales as well)
- Can be switched between Mill, Lathe, Grinder and EDM
- Supports both English and Metric units (in/mm display)
- Absolute and Incremental measuring mode
- Center line (1/2) function
- Sub datum (200 points)
- Linear drilling function Mill Mode
- Bolt circle (PCD) machining in Mill Mode
- Incline and oblique plane machining Mill Mode
- Simple and Smooth Radius machining Mill Mode
- Asymptotic machining of inner cavity (chambering) Mill Mode
- Radius/Diameter function in Lathe mode
- Tool compensation with 200 tools library in Lathe mode
- Taper function in Lathe mode
- Axis summing in Lathe mode
- Filter in Grinder mode
- Linear and non-linear error compensation
- Auto Zero/reference function
- Calculator with trigonometric functions
- Sleep Mode
- Power Off memory
- 100-240V, 50/60Hz universal AC power
- Mounting Arm and hardware included
- ISO 9001 certified quality control, CE certified
