- Nov 3, 2012
- 97
The compressor guy should have started a new topic. It would be normal for the lights to dim if you put the lights on the same circuit as a 1 horse motor. Even a half horse motor will cause a slight dimming in lights if you put it on the same circuit. And Compressors are one of the machines that has a very high starting load. Motors should have their own circuit, whether 110 or 220. If in your case, if that is not possible then you will have to put up with dimming lights. That is just the nature of the beast. If your light are on separate circuits and they are still dimming the lights, then you have overloaded the panel, or your service wires are too small.
