My 2 cents,
to oversimplify, it's kinda like having a Diesel in a Big Rig VS equipping the Rig with a gasoline engine of the same displacement.
both engines when geared correctly can transmit large amounts of power to the ground.
The reason Diesel engines are used comes down to efficiency, it an internal combustion engines' case it's Volumetric Efficiency.
there is more energy per gallon available to a diesel engine than there is available to a gasoline engine of equal displacement.
I would say that running a piece of equipment on the highest voltage available is the most efficient. Power Companies transmit over 50,000 volts because it's more efficient and then transform it down to 460/240/120 for us to use.
why do you think there are 460/480 volt systems , because it can do more work(higher potential difference) with less current
creating the sought after efficiency.
Would you rewire your house for 24 volts for efficiency and then try to fire up a 10 hp RPC on 24 volts (or 12 volts or 6 volts)???
not unless you have a couple hundred(thousand) amps to spare!!!!
But, you could fire off that 10hp RPC on 240 volts easily and even easier on 460 volts due to the higher potential difference between phases that essentially is proportionate to the amount of work that can be completed in a given time(horsepower)
in hobby equipment the effect is very minor, most times motors less than 2 hp are utilized and the currents are relatively low,
but once you start getting out of the 15 hp range you start getting into the 460 volt zone where it is more efficient to go with larger voltages to bring the currents down .
If i were in your shoes i'd run everything i could on 220 or 221, whatever it takes!!:lmao:
Good luck
mike
