A couple of d-11’s and roll it back on its wheels. It’s now empty, nowhere near 1.3 millions pounds.Crane? I don't think so...
Payload: 401 tons
Engine: 4000 hp
GVW: 1,375,000 lbs
Methinks they're gonna have to take it apart, turn it over, and reassemble it again, right side up!
I hope that is not a real photo from today!
It will require a lot of work to prep before they try to right it and event then the concern if you try to do it with D11's is that once it hits the tires you are going to have to have a way to check all that weight and momentum to prevent it from continueing. Not an easy job by any means in my mind.A couple of d-11’s and roll it back on its wheels. It’s now empty, nowhere near 1.3 millions pounds.
Not an easy job for sure but definitely not insurmountable. Can always have it tied to dozers holding it back to slow the hit.It will require a lot of work to prep before they try to right it and event then the concern if you try to do it with D11's is that once it hits the tires you are going to have to have a way to check all that weight and momentum to prevent it from continueing. Not an easy job by any means in my mind.
I agree, it can and surely will be done. But not an easy task. Would be fun to watch.Not an easy job for sure but definitely not insurmountable. Can always have it tied to dozers holding it back to slow the hit.
I can’t find it now, but I saw a YouTube video of a bunch of mining trucks (maybe 20) pulling a huge dragline out a lake.
