I didn't know they made a mini, so I can't comment on the pros and cons of full size vs. mini. I can't imagine there's much difference other than compatibility with the size machinery you have.I have been eyeing a Haimer for some time. How did you decide which one to buy? They make a mini also.
Robert
+1 on the Haimer 3-D taster. I have one on my Tormach and use it when accuracy matters. Otherwise, I use a passive probe. My limit to repeatability is the lost motion in my machine, not the Haimer.I have no complaints on mine. There is absolutely zero guess-work in finding an edge or center on a workpiece. Centering is a piece of cake: On flat stock, simply find the edge on one side; zero the DRO; move to the other side and find the edge; your DRO will now read the exact length or width of the piece. Center is half the distance. Round stock is just as easy using the same approach. You don't even need to be exactly on the diameter as long as you don't change the height of Haimer. Center will be half the distance between the two readings. Quite literally, it only takes seconds.
ih uses the whole hood. i saw a JD in a field and the engine took up about half of the hood. they could get a lot more power.The best thing about the IH's were the motor. Everything else, Deere did better.
The 9, 10 and 14xx IH tractors and JD 4XXX series both had 6 cylinder engines. IH used the 414s and 436. Deere actually had the larger 466 in the 40 series and later. The IHs were better on fuel and tend to start better in cold weather. Deere had plenty of power.ih uses the whole hood. i saw a JD in a field and the engine took up about half of the hood. they could get a lot more power.
Ouch! $500 is way more accurate than I am.There are many advantages to having a large family: one wife, four sons, one daughter, four daughters-in-law, one son-in-law, eleven grandsons, two granddaughters, and one grandson-in-law. When a crowd that size pools its resources, you can get something you want for your birthday that you could NEVER justify purchasing for yourself in a hobby shop. Best edgefinder on the planet (man, these things have gone up):
Haimer Universal 3-D Sensor with 0.200" Ball Dia. Short Probe Germany | eBay
Short Probe Germany. The 3D-Sensor is clamped into a tool holder and inserted into a milling spindle. Once clamped into the machine spindle, the run-out (T.I.R) is fully adjustable to Zero. Tolerance(+ -): with short sensor insert: Radial 0.0004", Axial.www.ebay.com
Heck, if you're gonna make it hurt, you might as well hit it really hard! I like mine, the passive probe is quicker and easier, but not as accurate. I have a job where I machine a profile on one side, flip it, and cut the mirrored profile on the opposite side. I've got about 0.0015" of lost motion on my Tormach X and Y. I use the Haimer for the set up on that job, minimizes the secondary work to blend in the step from the two set ups.Ouch! $500 is way more accurate than I am.
I think I'm gonna need a lot more kids and grandkids before I end up with that one.Heck, if you're gonna make it hurt, you might as well hit it really hard! I like mine, the passive probe is quicker and easier, but not as accurate. I have a job where I machine a profile on one side, flip it, and cut the mirrored profile on the opposite side. I've got about 0.0015" of lost motion on my Tormach X and Y. I use the Haimer for the set up on that job, minimizes the secondary work to blend in the step from the two set ups.
Bruce
Bruce,Heck, if you're gonna make it hurt, you might as well hit it really hard! I like mine, the passive probe is quicker and easier, but not as accurate. I have a job where I machine a profile on one side, flip it, and cut the mirrored profile on the opposite side. I've got about 0.0015" of lost motion on my Tormach X and Y. I use the Haimer for the set up on that job, minimizes the secondary work to blend in the step from the two set ups.
Bruce
