The reason is that many vises are not meant for that kind of load. I did that once. (Use the vise as a press.) The vise nut, which was made out of cast iron broke, rendering the vise useless. Vise was old and off-shore so no spare parts. Couldn't get the remnants of the nut out of the vise base. No amount of coaxing, or hammering would release the lower part of the nut. Had to junk the vise. So proceed with caution.That setup is kinda awesome! Ya know, a few decades ago (more like 40 years), I was told that "vises are not to be used as presses or anvils. Presses are for pressing and anvils are for hammering against. Vises are for clamping"
How did you do that? Wouldn't the thin rod just push away from the knurler? Or is that not a bump knurler?For the first time, I put the face plate on my PM-1030V (this was very easy & self-explanatory).
I turned a handle for a lathe chuck key.
Question was more about deflection, rather than how the rod was turned. Didn't the rod bend a lot while knurling, or did you have a follow rest? The rod is rather long relative to it's diameter. Is that a bump knurler, or a different kind? I've only knurled something once before, and it took a relatively large amount of force. That's why I was asking.I took off the lathe dog before I snapped the photo.
