made a counterweight system for my drill press. With the XY vise on the table and the table lock underneath it was both heavy and awkward to adjust the height of the table. It's only taken me 8 or so years to get round to this
starting lump of 12x12x1" alu. It's knarly looking from spending some time in the swimming pool holding something down. I think I might be over the size limit of my HF 4x6" bandsaw.
squared off and the middle bit holesawed out. That took a while.
bored to size. First time using the boring head to bore a hole, funnily enough.
various holes drilled and tapped, clamp cut in half
No pictures of the little studs I made - 3/8-16 threaded on one side, sized to fit the bearings and a tapped M5x0.8 hole in the middle. 2 of the pulleys were repurposed from an archery stand I made a while back, 2 were made for this. Simple U groove and a spare bearing pressed into the middle. 2 Alro, 1 Ol'Roy, 1 DelMonte peaches and 2 unknown (probably dogfood) cans filled with lead melted down from car batteries (bad idea, don't do it) and lead weights from the scrap yard. 19lb each side. Old outside dog leash cable (got run over by the car one too many times) goes from the right hand set of cans, over the pulleys, through the table, up to the next set of pulleys and then down through the LH set of cans. There it doubles back over a piece of steel rod and back up through the cans and gets tied off.
works really well. Holds the table still when the lock is released and takes only a little nudge to go up or down, then holds it still until the lock is tightened.
Extra bonus - I no longer have a large back of lead wheel weights to stub my toe on next to my mill. Weirdly some of the wheel weights didn't melt, maybe they're steel or some other metal.
Very nice.made a counterweight system for my drill press. With the XY vise on the table and the table lock underneath it was both heavy and awkward to adjust the height of the table. It's only taken me 8 or so years to get round to this
What kind of car?Oh, and I got my stupid car that I took completely apart to idle on it's own for the first time in 19 years. I need to tweak the carburetor to get it to run right, but it's coming.
What kind of car?
