The have decided to work on my mule
Years ago i removed the recoil starting system and installed a electric starter, alternator and Electric syste.
The mule had sat for about 5 year.
today is decited to finish the project.
installed new battery, tried to turn over the engine starter wouldn’t work. After a couple hours of playing with it I replaced the battery cables, now that the starter is working property it is Time to focus on the fuel system.
remover the gas tank. Removed the mechanical fuel pump. Made a blank plate. Bent a new fuel line from the. Gas filter to the carburetor ( tight space) I used brake tubing. Turned out better than I was expectin.
next is to install gas line from the gas tank to a pre electric fuel pump, and make a bracket to mount the filter and pump.
