- Oct 18, 2016
- 2,852
There's another alternative: fabricate a wrench holder with a microswitch built in so that the mill won't start unless the wrench
in in the holder. Take a bit of work, but would pretty much guarantee that you won't make that mistake. I you're like me, you'll
just come up with another mistake to replace it.
Before I retired, I worked for an airline. They occasionally had a problem with ramp personnel driving mobile ground power carts
away from the aircraft while forgetting to remove the power cord. This damaged the connector and sometimes the airplane.
The solution was to wire the cart such that the power cord had to be plugged into an outlet on the cart before it could be moved.
Solved the problem.
Solved the problem.
