- Sep 28, 2013
- 4,403
forcing a wire through the hose isn't really going to tell you anything other than if there's a hard blockage. You'd need to use a syringe of brake fluid and try to force fluid through from either end.
For the tires, if anything they're heavily overinflated. Not sure what the door specs on your car are, but 32-35psi is a more normal range. Have you had an alignment done recently? That'd be the first step. If that doesn't fix it then you have something worn in your suspension (shocks and/ or joints) that either causes bouncing or allows the tires to pull out of alignment.
Had that issue on the rear tires of a 2000 Focus (newer and fewer miles than your Peugeot) and it only went away after replacing the rear dampers, springs and suspension joints. Replacing one thing (dampers say) only fixed part of the problem. Also saw this on a friend's Taurus, replacing the rear shocks fixed that. She was getting bad cupping after just a few hundred miles and the shocks were shot.
