Another POTD making a "Sharpie Rejuvenator". I can't take credit for the idea, remember seeing the post here from a much "sharpier" guy than me.
Arbor is some Delrin rod stock on hand. Holder for the Sharpie was a piece of EMT conduit. Plugged the hole at the bottom of the tubing with a piece of Delrin.
It works really well though the spin time depends on the marker. As you can see from the photo below, a 30 second spin cycle at 800 RPM blew the ink out of the Sharpie. About 5-10 seconds worked best. No more shaking the markers trying to get them to write.
Thanks for looking!
Bruce
Chucked up a Delrin round. Faced, center drilled, tap drilled and power tapped a 10-24 hole.
Threw the Delrin in a 5-C collet and square block to machine a round into the end where the EMT attaches. A 7/8" end mill was close enough to the OD of the EMT. You may notice the width of my square collet block written on the block. It's a convenience thing so I don't have to measure the block width and divide by 2 every time it's used. The mill's DRO is zero'd on the fixed jaw, so easy peasy to get on the center line.
Drilled a clearance hole through for a mounting screw and a relief on one side for the head of the 10-24 mounting screw
Made a plug for the bottom from a Delrin round. Turned a shoulder and parted. I know how thoroughly you guys look at the background of photos. I think the light threading was to check a QCGB out for someone on this forum with a G0709 lathe.
Pressed the bottom plug in the EMT, then spotted, tap drilled and power tapped on the Bridgeport.
Drop a Sharpie in the end of the tube and spin away. Yes, it's not balanced and vibrates some, but my G0709 weighs around 1400 lbs. so no walking across the floor.
Before and afters of a few markers. 5-10 seconds at 500-800 RPM's works well. 30 seconds, not so much unless your intent is to do some painting.
