The horizontal band saw got a bit of overdue attention. The hole for the main locking bolt through the "fixed jaw" was somewhat bigger than the 1/2" bolt so I turned a small plug, MIG welded it into place and redrilled the hole to be a nice snug fit for the bolt to pass through. The edge of the plug is just visible. Then I set the fixed jaw to the blade using a square and the good old "hairy eyeball" and locked it down.
I needed to cut a short length off a 4" diameter round.
It took a bit over 70 minutes (using a 6 tpi blade)
I measured the thickness at 8 points.
32.75, 32.65, 32.39, 32.60, 32.75, 32.52, 32.90, 32.94
max minus min = 0.55mm or 21 thou
I am happy with that.
I also cut a 1" thick piece of flat at almost max capacity of the saw.
That took about 50 minutes.
That came out spot on at 81.51mm!
Perfectly parallel.
By my reckoning it is set for square just right!
The next thing to sort out is the down force when cutting, it definitely cuts better with some extra fingertip pressure.
Also, it just has a single pulley, and I haven't done the sums yet to work out what speed it is actually cutting,
I have a big bucket of old pulleys, I'm sure there are some options if need be.
Anyway, for the $120 I paid for it a few years ago, I am more than happy with it.
Pete
