- Sep 28, 2013
- 4,392
Installed the Z axis DRO sensor and magnetic tape.
nice clean install! what brand DRO are you installing + where did you get it from?
Today was install my new 1500W under desk heater day. In the mornings I like to sit in my bathrobe, drink coffee, answer emails and surf H-M and as the weather is getting colder my legs get cold. I have been using a portable heater but it is really bulky and at least 40 years old with no safety systems in it. And I have had to repair it a few times just to keep it running. I'll keep it around as a backup, but it's really time to retire it.
Nothing too special about the install except I added a feature..... Analog heat control.
So this started out life as a standard wall heater https://www.amazon.com/Broan-Heater...coding=UTF8&psc=1&refRID=6BMHY6KKMVVFQWQ550X1
This heater is really designed for in-wall mounting, but surface mounting is acceptable. I did use some 1 inch standoffs so it has an air space behind the heater housing, and good clearance all around.
This is a 2000 watt light dimmer, handles the 1500 watt heating element just fine.
I have no idea what Robot Check means, I didn't put that in, it is a link to the Amazon page.
This allows me to adjust the power input to the heating element and thus the actual temperature of the output air rather than just having the heater turn on and off with the thermostat, which leaves you hot or cold, but rarely just right. I left the thermostat and safety controls in place, and am also turning the system on and off with a 20 amp light switch mounted in a convenient location next to the dimmer.
The system run on 120V and plugs into the power strip on the back of my desk. Now before you say a heater should not be plugged into a power strip (and in most cases you're correct) My power strip is 12 duplex, 15/20 amp, industrial rated receptacles, complete with surge protection and fed by a dedicated 30 amp, 120V circuit and all wired with #10 wire. I built that power strip back in the day when big monitors were 400 or 500 watts, my total desk power draw was almost 2KW when I had 4 monitors connected. Today with the energy saving flat screens my total desk power draw is about 100 watts, including the TV.
Now for the fun part, you can't just connect a light dimmer to a stock heater. The fan motor would not like that at all. So a bit of modification is needed. Of course the heating element is a resistive load just like a light bulb and is perfectly happy running on a light dimmer.
So we have to separate the motor and heating element power, but keep the heater thermostat and thermal overloads intact.
So cut the white wire at the red X and insert the light dimmer.
The light dimmer doesn't care if it's on the neutral side, works just fine. So doing it this way, none of the other wiring is disturbed, and the safeties and fan motor are happy. This of course does require running an extra wire into the heater, but a small price to pay for something that works the way I want.
I was going to try to make a joke about putting the blower on HIGH and blowing your skirt up, but realized you were sitting there in a robe.Today was install my new 1500W under desk heater day. In the mornings I like to sit in my bathrobe, drink coffee, answer emails and surf H-M and as the weather is getting colder my legs get cold. I have been using a portable heater but it is really bulky and at least 40 years old with no safety systems in it. And I have had to repair it a few times just to keep it running. I'll keep it around as a backup, but it's really time to retire it.
Several things illegal under Oregon State law with this post due to the dangerous conditions created, please do not duplicate this information.
see 210.21, 404.3, 404.21.
