- Dec 27, 2014
- 4,093
With that done, make a mount for it to read when you move the compound in. So you know how much cut you are taking.
a few different projects over the past few weeks.
Some T-nuts. Got a mostly complete clamping kit with my mill but it only had 1 T-nut. Being a tight ar$e I decided to make my own from a piece of scrap bin steel
action shot with a 1/4" rougher
blank finished
drilled and tapped
then cut in my bandsaw (which resulted in me making a work stop..), with a couple needing some FTF work (file to fit). Some of them ended up with the hole towards one end and I'm not entirely sure why, but they'll work fine
that should do me for T-nuts for a while!
One idea while making T nuts is to make a few with a small tapped hole to one side of the slot. Keep them around with a few threaded rods and nuts with washers. Because once in a while you will have a setup where the large screw in the middle is just a little in the way, pushes the hold down over enough not to lay flat.. The small screws near the side of the slot can come in handy to hold the job straight on occasion. And since you are making them anyway free to make.
can you show us your T Nut with this setup? I am having a hard time envisioning it.
