- Jul 14, 2017
- 2,455
Today i spent some time assessing the health of the engine in the little 4x4, first i did a compression test and got really good numbers on cold and hot engine, all with in 0,5bar one from other, next i check the coolant system and the walter pump is leaking also some of the hoses are dryroted and the heater core is not connected, then i decided to try adjusting the timing chain, it is rattling like there is a bag of stones in the engine i follow the procedure, had to make a hand crank, to turn the engine over by hand and the chain is much more quiet, i still need to check the oil pressure when cold and warm. After dealing with the engine, i moved to the interior, managed to cut out the passenger seat, the previous owner had welded in some Ford seats directly to the floor pan and then i realized that the rear footwell isn't even welded in, some one put down some sheet metal and screw in with couple of self tappers and pop rivets, so i removed them and removed already rusted sheet metal and found this. One side is welded from underneath other just cut out, i'll be cutting some more out and making a new piece. It was a long day in the garage.
