- Dec 27, 2014
- 4,093
Good buy. I've tried to find them, don't often find them.
you do have a way, consider the mit set your master, test that against your Chinese set. so ring the mit, then do the same for the Chinese set, and validate. do a few different block configs randomly. Don't reuse the same block unless you find your off and want to find out which one.
I'm hoping it'll tell you how accurate your set is it will show you the tolerances whether they're met or not yes you should expect some off but within the tolerance, right?Ok, when I get a chance I'll unwrap & clean all the Chinese ones & test them out. I'm not sure what that is going to tell me though cause the Mitu it set is one grade higher. Not a fair comparison no? For a fair comparison I should have both sets in the same grade?
