- Oct 30, 2012
- 956
Nice work ddickey. Handy little gizmo.
The joints can be separated quite easily. A sharp bend will pop them. The pliers are for reassembling the joints. It can be done without the pliers but it is difficult.BTW is it possible to take the joints apart to shorten it?
I believe so. They sell a special "pliers" to make popping the segments apart easier bit I'm thinking you can do it sans the tool with a little grunting.
I do more than I care to think about. Typically, I will model all but the simplest projects in SolidWorks before making any cuts so I have a fairly good idea of what the finished project will look like. This tends to reduce "engineering changes" greatly. However, there are numerous instances when I will realize that there is a better way to accomplish the task. Sometimes these result in gotcha's when they adversely affect a different part of the project.While I was turning down more of the spindle yesterday. Yep, you guessed it. I decided to make a change on the design. It's been a while since I designed anything and I guess I forgot a few things.
Made me wonder how many people change things from their original design as they go along.
Probably nothing worth keeping. I have scrapped out quite a few and don't remember keeping any power supplies. I may have kept a transformer or two but they are generally fairly low power. With 12 volt wall warts so common, it doesn't make a lot of sense to build your own supply.In the spirit of cleaning the shop? is there a usable 12V power supply inside an old CRT monitor? Before I consign it to the dump?
