I was in "fixing my truck" mode today, and one of the things I fixed was the door handle for the rear suicide door on the drivers side. I use it quite a bit, particularly in the winter, and the handle regularly breaks. The assembly is primarily plastic, and the handle you pull on rotates around a pin, and a slab of plastic on the other side of the pin presses against the mechanism to unlatch the door. So, you pull on the handle, and the plastic pushes against the latch, and then you pull the door open with the handle. However, if you pull on the handle too hard (either just to open the door quickly or if the door sticks closed, say, being frozen shut in winter), or just through use, that plastic slab bends/breaks off, and you have to buy another one for about $50 for a knockoff or $100+ for an OEM one. Every year I've had the truck, I've had to buy 1 or 2 of these, and the last time it happened, I already had a spare to install, but I promised myself when that one failed, I would fab up the handle out of metal so it wouldn't bust.
That day was today.
Here's the handle I made next to the busted one (that extension that is about 3/8" thick and 1" or so long is what keeps failing:
New handle installed in mechanism:
Installed in door:
Works fine and I think the plastic housing is bulky enough around where the pin goes through the housing will take longer before it fails.
And now I'm off to pick up my victory pizza.
