Installed a new garage door opener in the garage attached to my house. Last summer, I closed it, and the door stopped on a piece of equipment in the doorway, and after that, the opener didn't work anymore. It was maybe 20 years old or so, from before the time they had to come with a sensor that something is in the doorway. I believe it was designed to "notice" when it closes on something, and auto-reverse, but it didn't this time.
Anyway, there was a Chamberlain 1/2hp opener for $150cdn on black friday, so I bought it and installed it today:
Today's lesson:
For attaching the wiring for the two sensors and the control panel, Chamberlain includes maybe 2 dozen or so staples that I suppose you hammer in over the wires to hold them in place. If I used them, there is 100% certainty that one or more fingers would be mashed by the hammer. Instead, I was going to use the stapler I know I have to hold the wires in place, but naturally, I couldn't find it. Went to the store and bought a cheap light duty Bostich manual stapler and short staples. I've used a variety of staplers before, so I get it out of the packaging, pull out the tray, not quite enough space for one row of staples, looks/feels like it can/should come out a bit further...nope...shouldn't have done that...unscrew it, push the tray in a bit, now it goes in all the way again...yay. Pull it out, break off part of the row of staples, put it on the tray, push the tray in...tray stops once the staples get to the body of the stapler. look at it a bit, nothing seems out of place, bit more force, and the tray with staples are in...yay. try it out, get that satisfying snap, but no staple is dispensed. try it a few more times, no staples. look at the side, the little window shows all red, indicating it's empty. try to pull out the tray and see what's up...nope, pulls out a little, but not like before and can't see any staples on the bit that comes out. unscrew the stapler again, take it totally apart, staples are on the tray right where I put them, nothing obvious to push them forwards to the dispenser. examine the tray, which also has the 'empty' indicator in red, notice that the red part is spring-loaded, but there's no obvious way (to me) to insert the staples on the tray, so the red part is behind them to push them towards the dispenser. Finally give up, look at the packaging for instructions on how to insert the staples. doh. you pull out the tray, then turn the stapler upside down and put the staples in the bottom, then push the tray back in.
So, RTFM.
