Yay, the plow worked well. The winch control worked nicely, the extensions go on and off with a minimum of fuss, and it did a nice job of clearing a sidewalk that snow that people walked on for sometime. It would occasionally catch on the grass beside the sidewalk, and that would stop the plow (or not, it sheared off the grass sometimes), but the snow was pushed to the side nicely and it did a decent job of scraping to the concrete. It's unlikely to be able to peel up harder-packed snow, like when cars pack it down, as that tends to be bonded better to the concrete and this machine doesn't have the weight/traction to be able to break it free.
As for "machining" content, I made another exhaust pipe for this machine, as the one I previously made doesn't clear one of the braces for the plow mount. Here's the new one, installed:
It's pointed up just to minimize noise. I may make a snow/rain cap for it to prevent the muffler from rusting out sooner.
As well, I noticed that I miscalculated the height that the front caster wheels are mounted at, as now it is noticeably tilted forward. It's not enough to cause a problem with the engine, so I'll fix this next spring when the plow comes off and the mower gets reinstalled (as getting the plow installed involves a lot of swearing while lying on the ground trying to get various holes lined up so a bolt or pin can get shoved through).
